Firmware pro Pentax K-3
Příspěvek od TomášFencl » 19 pro 2013, 15:27
Changes to V1.11 (22. 8. 2014)
Corrected – When shooting image after using the Built-in flash, Exif data of shutter speed is not updated on Version 1.10.
Added automatic reset function when detecting rarely occur abnormal motion of the sequence.
(When automatic reset function is operated, latest setting will be reset)
*Contents of [Version 1.10] and earlier version will be also updated.
Changes to V1.10 (10. 7. 2014)
Added Diffraction Correction on Lens Correction.
Shortened processing time for Digital Filter and Color Fringe Correction.
Improved stability for AWB (Auto white balance) performance.
Changed to ISO Bracketing when using Exposure Bracketing on TAv mode.
*Contents of [Version 1.03] and earlier version will be also updated.
Changes to V1.03 (6. 3. 2014)
Correspond to HD PENTAX-DA AF REAR CONVERTER 1.4X AW.
Improved stability for general performance
*Contents of [Version 1.02] and earlier version will be also updated.
Changes to V1.02 (5. 2. 2014)
Added Bracket shooting in [Anti-Aliasing Filter Simulator].
*Contents of [Version 1.01] will be also updated and following contents will be improved.
Improved stability of battery level indicator when using with battery grip.
Optimized performance of continuous shooting when setting AF.C mode.
Changes to V1.01 (19. 12. 2013)
Shorten processing time of combining time for HDR Capture.
Improved performance of continuous shooting when using phase-matching autofocus.
Extended enlarged display time for live view.
Caution
Only PENTAX K-3 users are permitted to download the firmware update.
Změny V1.11 (22. 8. 2014)
Opraveno - ve verzi 1.10 při pořízení snímku po použití interního blesku se do Exif dat nezapsala rychlost závěrky.
Přidána funkce automatického resetu při zjištění abnormálního pohybu závěrky (?).
(Při funkci automatického resetu budou nastaveny poslední použité hodnoty).
* Obsah [verze 1.10] a starší verze jsou také obsaženy.
Změny V1.10 (10. 7. 2014)
Přidána Korekce difrakce na korekce objektivů.
Zkrácena doba zpracování pro digitální filtr a korekci Color Fringe.
Vylepšená stabilita AWB (Automatické vyvážení bílé).
Změněn ISO bracketing při použití expozičního bracketingu v režimu TAv.
Zlepšena stabilita pro zvýšení výkonnosti.
* Obsah [verze 1.03] a starší verze jsou také obsaženy.
Změny V1.03 (6. 3. 2014)
* Obsah [verze 1.02] a starší verze jsou také obsaženy.
Změny V1.02 (5. 2. 2014)
Přidán bracketing pro [Anti-Aliasing Filter Simulator].
Zlepšení stability pro celkový výkon.
*Obsah verze [Version 1.01] je tímto updatem také nainstalován.
Vylepšená stabilita indikátoru stavu baterie při použití s battery gripu.
Optimalizovaný výkon sériového snímání při nastavení režimu AF.C.
V příloze také postup použití bracketingu s Anti-Aliasing Filtrem
Změny V1.01 (19. 12. 2013)
Zkrácení času zpracování při snímání do HDR.
Zlepšený výkon sériového snímání při použití fázového ostření.
Větší prodloužení času zobrazování při live-view.
Pozor
Tento update firmware je určen pouze pro uživatele K-3.
1.11_MAC.zip
(12.68 MiB) Staženo 128 x
1.11_WIN.zip
(12.79 MiB) Staženo 161 x
1.10_Mac.zip
(12.68 MiB) Staženo 143 x
1.10_Win.zip
(12.78 MiB) Staženo 149 x
Diffraction Correction Function.zip
(136.46 KiB) Staženo 125 x
1.03_Mac.zip
(12.75 MiB) Staženo 130 x
1.03_Win.zip
(12.64 MiB) Staženo 153 x
Bracketing_Anti-Aliasing_Filter.zip
(132.65 KiB) Staženo 134 x
1.02_MAC.zip
(12.65 MiB) Staženo 137 x
1.02_WIN.zip
(12.75 MiB) Staženo 139 x
1.01_MAC.zip
(12.64 MiB) Staženo 129 x
1.01_WIN.zip
(12.73 MiB) Staženo 156 x
Zpět na „Firmware“
