ahojte, kupil som si MZ-5 a bojujem s AF...mam jediny objektiv s clonovym kruzkom, FA77/1,8Ltd, ale pri foteni na AF nemam vobec predstavu ci je to spravne zaostrene (3 AF body, ale ked nechcem stredovu kompoziciu, musim jedine zaostrit na stred a prekomponovat, to si posuniem DOFku).
...menil niekto uz na MZ-5 matnicu? (vybrat by sa mala dat isto, videl som vo fotaku pri matnici kovovu zapadku,hm)
...najradsej by som tam chcel rastrovu, ale co najlacnejsiu, nechcem do toho davat 100euro ako za Ec-A co som daval do K5IIs.
...skusal som nasadit aj DA15/4, ta fest vinetuje, Sigma 10-20/4-5,6 EX DC je od 14mm uplne v pohode, akurat na MZ-5 nemozem nastavovat clonu.
...nemate mi niekto doporucit, resp. predat daky sirokac s AF na krajinky?
Pentax MZ-5 a vymena matnice
Re: Pentax MZ-5 a vymena matnice
Mam mz-6 aj mz-5. Na mz-6 nemusia byt objektivy s clonovym kruzkom.
Matnica sa da pouzit z mz-m (klin s mikrorastrom) a jednoducho vymenit.
Siroke sklo som zohnal FA 20-35/4 a je OK.
Sigma 10-20 je na FF problem, lepsia by bola 12-24 ta je uz FF. Vyborny je aj manualny samyang 14/2,8.
Read more at: http://www.pentaxforums.com/forums/pent ... z2irfvDaiX
i've just done it !
it took me a while to find the perfect focusing screen
(here is the list of all focusing screen done by Pentax for MX and LX and their own application : http://www.bdimitrov.de/kmp/misc/foc...ens/index.html )
replace the standard mate screen by this one : microprism on the outer ring and split screen in the inner ring (Pentax SC-1).
Only one thing need to be done : just cut a very little slice of the botom side, on 0.5cm to fit it in the MZ-5n.
Now it's the same screen on my MZ-5n and SuperA.
i've just done it !
