Oficiální K-3 specifikace a umístění na webu Ricohu!
fyby
Příspěvek od fyby » 07 říj 2013, 12:20
Zřejmě nejsou specifikace ještě kompletní, něco je zkopírované z K-5II, něco TBD...
Type
Digital SLR
Sensor
Type: CMOS w primary color filter and integrated Shake/Dust Reduction sensor movement system
Size: 23.5 x 15.6mm
Color depth: 8 bits/channel JPG, 14 bits/channel RAW
Effective pixels: 23.35 MP
Total pixels: 24.71 MP
Recorded resolutions
Still: Jpeg –
L (24M:6016x4000),
M (14M: 4608x3072),
S (6M: 3072x2048),
XS (2M: 1920x1280)
RAW – L (24M:6016x4000)
Movie (resolution/FPS):
Full HD (1920x1080, 60i/50i/30p/25p/24p)
HD (1280x720, 60p/50p/30p/25p/24p)
Quality levels: ★★★ Best, ★★ Better, ★ Good, RAW (14-bit)
Dust Removal: DR II (ultrasonic vibration to low pass filter) with Dust Alert function
Lens
Type/construction: PENTAX KAF2 bayonet stainless steel mount
Usable lenses: PENTAX KAF3, KAF2, KAF, and KA (K mount, 35mm screwmount, 645/67 med format lenses useable w adapter and/or restrictions)
SDM function: Yes
Power zoom function: Yes (power zoom only)
Focus System
Type: SAFOX 11 TTL phase-matching - 27 point (25 cross type focus points in the center)
Focus modes: AF Single (w focus lock, focus/shutter priority selectable), AF Continuous (w focus/FPS priority selectable), Manual
Focus point adjustment: Spot, Select, Expanded Area (S, M, L), Zone select, Auto (27 AF points)
Viewfinder
Type: Pentaprism
Coverage (field of view): 100%
Magnification: 0.95X (w 50mm F1.4 at infinity)
Standard focusing screen: Natural-Bright-Matte III (interchangeable)
Diopter adjustment: -2.5m to 1.5m
Depth of field preview: Optical (diaphragm stop-down), Digital
LCD Monitor
Type: 3.2” TFT color LCD with brightness/saturation/color adjustment AR coating and air-gapless glass.
Resolution: 1037K dots
Wide angle viewable: Yes
Flash
Type: Retractable P-TTL popup flash
Guide number: 13m (ISO 100)
Coverage: 28mm wide angle (equiv 35mm)
Flash modes: Auto, On, Redeye, Slow Sync, Slow Sync + Redeye, Trailing Curtain Sync, High-speed sync, Wireless, Manual
Flash exposure compensation: -2 to 1 EV (1/2 steps)
External Flash
Type: Hotshoe (P-TTL), high speed sync and wireless w PENTAX dedicated flash, X-Sync Socket
Synchronization speed: 1/180 sec
Storage Media
Internal memory: n/a
Removable memory: SD, SDHC, SDXC, EyeFi, FLU
Interfaces
Ports: USB 3.0 hi-speed, AV out, HDMI out, DC in, cable switch, 3.5mm stereo microphone, X-sync socket
Video out: HD (via HDMI), NTSC, PAL
Printer interfaces: n/a
Power Supply
Power source: Rechargeable Li-Ion battery D-LI90, D-BG5 Battery Grip (optional) with trays for 2nd D-Li90 battery or 6x AA batteries
Recordable images: Approx 720 (approx 560 w 50% flash, CIPA)
Playback time: Approx 370 min
Movie recording time: Approx 25 min (automatic overheat shutdown protection)
AC adapter available: Yes - (optional) K-AC132
Physical Specs
Body dimensions (W x H x D): 5.17in x 3.94in x 3.05in
Body weight
Without battery or removable memory: 25.2 oz
Loaded and ready: 28.2 oz
Construction material(s): Magnesium alloy shell over metal chassis
Weather resistant: Yes (92 special sealing parts)
Operating temperature: 14-104°F (-10 to 40°C)
Language Support
English, French, German, Spanish, Portuguese, Italian, Dutch, Danish, Swedish, Finnish,
Polish, Czech, Hungarian, Turkish, Greek, Russian, Korean, Chinese
(Simplified/Traditional), Japanese
Image Stabilization
Type: Sensor-Shift Shake Reduction with rotational compensation (3.5EV TBD)
Electronic level function: Yes, verification via viewfinder and LCD panel
Metering System
Type: TTL open aperture metering using 86K pixel RGB sensor
Sensitivity range: EV -3 to 20 (ISO 100, 50mm F1.4)
Multi-Segment: Yes
Center weighted: Yes
Spot: Yes
Exposure compensation: +/- 5 EV (1/3 and 1/2 steps)
Exposure lock: Yes
Exposure bracketing: Yes (2, 3, or 5 frames, up to +/- 2 EV in 1/3 or 1/2 steps)
ISO Sensitivity
Auto: ISO 100-51200 (1, 1/2, 1/3 steps), Auto ISO range selectable,
Bulb mode: Auto ISO n/a
Manual: 100-51200 (1, 1/2, 1/3 steps),
White Balance
AUTO WB, Multi Auto WB,
Daylight, Shade, Cloudy, Fluorescent Light (D: Daylight Color, Naylight White, W:Cool White, L:Warm White), Tungsten Light, Flash, CTE,
Manual mode(s): Yes, Manual WB (up to 3 settings), Color Temperature Configuration (up to 3 settings), Copying the white balance setting of a captured image* WB fine adjustment available in all modes
Shutter
Type: Electronically controlled, vertical-run, focal plane shutter
Shutter speed: 1/8000 to 30 sec (1/3 or 1/2 EV steps), Bulb
Capture Modes
Mode selection: Green, Hyper Program (P), Sensitivity Priority (Sv), Shutter Priority (Tv), Aperture Priority (Av), Shutter & Aperture Priority (TAv), Metered Manual, Bulb, X-Speed, USER (3 presets).
Custom Image Modes: Bright, Natural, Portrait, Landscape, Vibrant, Radiant, Muted, Bleach Bypass, Reversal Film, Monochrome, Cross Processing,
HDR: Auto, HDR1, HDR2, HDR3, Exposure Bracket Value adjustable, Automatic composition correction function
- All include gamut radar and fine adjustment of saturation, hue, high/low key, contrast, and sharpness (regular and fine adjustment scales). Monochrome mode includes adjustments for filter effects (green, yellow, orange, red, magenta, blue, cyan, infrared), toning (sepia, warm/cool), high/low key, contrast, and sharpness (regular, fine, and extra sharp adjustment scales).
Green simplified mode available: Yes
P/A/S/M/B: P, A, S, M, B (extended modes Sv, TAv)
Date stamp: n/a
Digital filters (capture): Extract Color, Toy Camera, Retro, High Contrast, Shading, Invert Color, Unicolor Bold, Bold Monochrome
Data record: Folder name (standard, date), file name (standard, customizable), embed copyright.
Drive Modes
Mode selection: Single, Continuous (H,M,L), Self-Timer (12s, 2s), Remote (0s, 3s, continuous), Exp. Bracketing (standard, timer, remote), Mirror up (standard, remote), HDR Capture (3 shots at 1EV, 2EV, or 3EV, 3 blend settings plus Auto, pixel alignment)
Multi-exposure: Composite Mode (Additive/Average/Bright) Number of Shots (2 to 2000 images), Interval 2000 shots, 2 sec to 24 hrs, time delay available)
Continuous FPS (JPG ★★★)
- Continuous H: Approx 8.3 FPS (60 JPG, 23 RAW)
- Continuous M: Approx 4.5 FPS (100 JPG, 32 RAW)
- Continuous L: Approx 3.0 FPS (200 JPG, 52 RAW)
Self-timer: Yes (12s, 2s)
Remote control: Yes, infrared (0s, 3s, continuous), cable switch
Playback Modes
Mode selection: Single frame, multi-image display (6,12, 20, 35, 80 segmentation), display magnification (up to 16, 100% display and quick magnification available), rotating, histogram (Y histogram, RGB histogram), bright area warning, Auto Image Rotation, detailed info, Copyright Information (Photographer, Copyright holder), Folder Display, Calendar Filmstrip Display, Slide Show Mode pallet: Image Rotation, Digital Filter, Resize, Cropping, Slideshow, Save as Manual WB, RAW Development, Index Print, Protect, Movie Edit, Extract JPG from Movie, Magnification: up to 16X, scrollable, quick magnification.
Digital filters (playback): Base Parameter Adj, Extract Color, Toy Camera, Retro, High Contrast, Shading, Invert Color, Unicolor Bold, Bold Monochrome, Tone Expansion, Sketch, Water Color, Pastel, Posterization, Miniature, Soft, Starburst, Fish-eye, Slim
File Formats
Still: RAW (PEF, DNG), JPG (EXIF 2.30), DCF 2.0 compliant
Movie: MPEG-4 AVC/H.264(MOV) - JPEG(AVI) for internal movie record
Custom Functions
Functions available: 27
Computer Requirements
*For device connectivity. Bundled software requirements may vary.
Windows: Windows 8 (32 bit/64 bit) / Windows 7 (32 bit/64 bit) / Windows Vista (32 bit/64 bit), Windows XP SP3 (32 bit)
Mac: Mac OS X 10.8 / 10.7 / 10.6
Battery Life
Dimensions
Weight
Body weight
Operating Temperatures
Operating Humidity
Zdroj: http://www.pentaxforums.com/forums/pent ... z2h28I4Kd9
RICOH:http://www.us.ricoh-imaging.com/dslr/K-3_
Vypadá to moc pěkně. Taky to vypadá, že
-PTTL zůstalo při starém, tzn. i synchro 1/180 s
-je kompatibilní i s eyefi
-přes flu card lze foťák ovládat (tj. z mobilu, bomba)
-lze ukládat raw na jednu a jpg na druhou kartu, tj. např. flu s menší kapacitou
Update:
-max 25 minut videa kvůli možnému přehřátí
-tři stupně rychlosti při sekvenci snímků
a teď buffer vážení:
-při 3 fps se do něj vejde 200 jpg nebo 52 rawů
-při 4.5 fps se do něj vejde 100 jpg nebo 32 rawů
-při 8.3 fps se do něj vejde 60 jpg nebo 23 rawů
Pokud bude rychlost podpořena opravdu dobrým AF, tak je to pro Pentax velký skok kupředu!
Dále:
-Video se dá ukládat ve 14bitech(RAW)..hmm
-Automatické rozdělení snímku do více segmentů pro vyvážení bílé
Dále:
-oproti K-5ii přibyl ve specifikaci high speed sync - takže je tu aspoň možnost fotit na vyšší rychlosti závěrky s bleskem - resp. odpalovat vestavěným bleskem v hss módu
Naposledy upravil(a) fyby dne 07 říj 2013, 13:43, celkem upraveno 6 x.
Re: Oficiální K-3 specifikace !
Příspěvek od matak77 » 07 říj 2013, 12:30
koukám že je i ta stříbrná edice, pěkný :)
http://www.us.ricoh-imaging.com/dslr/K- ... on_Silver_
Naposledy upravil(a) matak77 dne 07 říj 2013, 12:35, celkem upraveno 1 x.
fyby
Re: Oficiální K-3 specifikace a umístění na webu Ricohu!
Příspěvek od fyby » 07 říj 2013, 12:32
Pěkná pěkná ;-)
miky_lbc
Příspěvek od miky_lbc » 07 říj 2013, 12:46
Je to tady... jediné drobné "zklamání" je pro mě ten BG5, stále jsem doufal, že tam bude pasovat BG4, když je v podstatě totožná :-(. Taky jsem stále doufal, že tam bude i WiFi, duální AF nebo nějaká turbovychytávka...
Nicméně tyhle věci nejsou až tak důležité, ale teď půjde o to, jak dalece to bude všechno fungovat. Pokud bude AF na úrovni toho, co před lety přinesla třeba 7D, bude to ohromnej posun dopředu v možnostech užití.
Tak a teď ještě doufat, že se rychle dostane do prodeje a brzy se objeví nějaké reálné testy a výsledky... už se nemůžu dočkat.
Jsem každopádně moc rád, že to s K3 myslí Ricoh alespoň tak vážně, že nahradil AF modul a PRIME. Je to dobré znamení, že není všem dnům konec (s Pentaxem).
fyby
Příspěvek od fyby » 07 říj 2013, 12:52
miky: s flu kartou to v podstatě wifi má, nicméně je to investice navíc...
Zafod
Příspěvek od Zafod » 07 říj 2013, 13:08
No vypadá to moooc pěkně :D Mě zaujal ten vypínatelný AA filtr, pěkná vychytávka...
Velbon Sherpa 600
miky_lbc
Příspěvek od miky_lbc » 07 říj 2013, 13:12
fyby píše:miky: s flu kartou to v podstatě wifi má, nicméně je to investice navíc...
Njn... ale flu karta je stejně jen "slabej odvar", představoval bych si, kdyby skrze WiFi jel i LV a mohl jsem kompletně ovládat fotoaparát, tak jako to dneska můžu dělat po kabelu.
Ale to je fakt jen už detail. To důležité je v tomhle případě hlavně AF...
miky_lbc
Příspěvek od miky_lbc » 07 říj 2013, 13:13
cport píše:Nicmene bude asi skoda chybejiciho ISO80.
To by mě hodně mrzelo... budu doufat, že se tam nakonec objeví.
miky_lbc
Příspěvek od miky_lbc » 07 říj 2013, 13:14
BTW: ... baterie budou stejné jako u K5. Čím dál méně to chápu s tím gripem. Podle fotek mi přijde jako naprosto totožný.
Třeba bude BG4 opravdu nasaditelná.
fyby
Příspěvek od fyby » 07 říj 2013, 13:17
No podle RICOHU můžeš s tou kartou:
-měnit clonu, rychlost závěrky a iso
-měnit zaostřovací bod
-fotit
-live view (orig. check live view image) ???
-pak samozřejmě přesun obrázků tam a zpět
Pokud by to live view přenášelo real time třeba do mobilu, bylo by to super. Pokud to je jen kontrola po vyfocení, taky dobrý.
JirKrato
Příspěvek od JirKrato » 07 říj 2013, 13:27
Myslíte že tato zpráva bude něco znamenat v cenové politice px nebo cashback kvůli zvidětelnění značky před Vánoci?
A teď přemýšlím zda jít pro tu K-30 nebo počkat na cenu tohohle modýlku... a teď babo raď.
Případně nenajde se někdo z Vás kdo bude mít hned pro pentax K-3 a nemá v plánu prodávat současné tělo když tak do Soukromých zpráv, ať to tu nezasí..me. Díky
Příspěvek od hilda4sea » 07 říj 2013, 13:52
Specifikace je opravdu skvělá. ISO 80 mi až tak moc nechybí, protože to stejně bylo jen virtuální a diference byla jen 20 ISO. Stále nechápu fíčuru zapínání AA filtru. Rozumím tomu dobře, že se celý snímač během expozice roztřese?
Co jsem v podrobném popisu nenašel (možná to tam je), je detailnější popis nového AF SAFOX 11. Jaké má možnosti a zda už má konečně prediktivní ostření.
Jinak je to dost dobré.
Příspěvek od duves » 07 říj 2013, 13:57
Ja si počkam na K-3II :wink: :mrgreen:
Miho
Příspěvek od Miho » 07 říj 2013, 14:02
Ano, však to tam je napísané zrozumitelne : the anti-aliasing simulator* applies microscopic vibrations to the image sensor unit at the subpixel level during image exposure, generating the same level of moiré-reduction effect as an optical anti-aliasing filter.
Mňa zaujímajú len prvé testy AF , ale už teraz cítim, že neodolám. Škoda , že som minulý týždeň minul našetrené peniaze na gitaru a combo :?
Naposledy upravil(a) Miho dne 07 říj 2013, 14:20, celkem upraveno 1 x.
Lukas_Gal
Příspěvek od Lukas_Gal » 07 říj 2013, 14:04
Podla mna je to super telo, ktore v tomto momente nema konkurenciu. Prinasa par z mojho pohladu prelomovych inovaci (multi-pattern WB, vypinatelny AA). 25 krizovych bodov je tiez daleko nad konkurenciou Konecne rozpoznavanie motivu pomocou 86k!!!!! senzoru atd. No podla mna proste super telo v APS-C segmente. 200 000 cyklov tiez podporuje teoriu profesionalne zameraneho tela.
Lukáš Gál,
http://www.lukasgal.com
Zpět na „Novinky a drby“
