Firmware pro Pentax K-5 II
Příspěvek od TomášFencl » 17 led 2013, 07:17
Firmware pro K-5 II
Changes to V1.07 (6. 3. 2014)
Correspond to HD PENTAX-DA AF REAR CONVERTER 1.4X AW.
Improved stability for general performance
*Contents of [Version 1.06] and earlier version will be also updated.
Changes to V1.06 (3. 10. 2013)
Corrected – Unstable performance may rarely occur in firmware version 1.05.
*Contents of [Version 1.05] and earlier version will be also updated.
Changes to V1.05 (12. 9. 2013)
Correspond to the AF assist light function by white LED light for auto flash unit [AF360FGZII] and [AF540FGZII].
Optimized contrast AF when using HD PENTAX-DA Limited series lenses
*Contents of [Version 1.04] and earlier version will be also updated.
Changes to V1.04 (18. 4. 2013)
Corrected – Switch operation may not rarely work during displaying Status screen in firmware version 1.03.
*If you have already updated to Version1.03, we are very sorry for this inconvenience. Please update to Version 1.04.
*Contents of [Version 1.03] and earlier version will be also updated.
Changes to V1.03 (7. 3. 2013)
• Improved the accuracy of exposure when using AA batteries.
• Improved stability for general performance.
*Contents of [Version 1.02] will be also updated.
Changes to V1.02 (31. 1. 2013)
• Optimized contrast AF when using [HD PENTAX-DA 560mmF5.6ED AW] lens.
Changes to V1.01 (17. 1. 2013)
• Enabled contrast adjustment on Monitor. (Added [contrast ]on [LCD setting ]menu)
Caution
Only K-5II/K-5IIs users are permitted to download the firmware update.
Změny V1.07 (6. 3. 2014)
* Obsah [verze 1.06] a starší verze jsou také obsaženy.
Změny V1.06 (3. 10. 2013)
Opraveno - vzácně se vyskytující nestabilita s verzí firmware 1.05.
* Obsah [verze 1.05] a starších verzí je také obsažen.
Změny V1.05 (12. 9. 2013)
Upraveno pomocné AF světlo při práci s blesky [AF360FGZII] a [AF540FGZII].
Optimalizováno AF pomocí detekce kontrastu při použití objektivů HD PENTAX-DA limited.
* Obsah [verze 1.04] a starších verzí je také obsažen.
Změny v1.04 (18. 4. 2013)
Opraveno - Přepínač operací nemusí občas pracovat při zobrazení stavové obrazovky ve verzi firmware 1.03.
* Pokud je již aktualizováno na Version 1.03, velice se omlouváme za tuto nepříjemnost. Prosím aktualizujte na verzi 1.04.
* Obsah [verze 1.03] a dřívější verze je také aktualizován.
Změny v1.03 (7. 3. 2013)
• Vylepšena přesnost expozice při použití AA baterií.
• Vylepšená stabilita pro celkový výkon.
* Obsah [verze 1.02] je také aktualizován.
Změny V1.02 (31. 1. 2013)
• Optimalizováno contrast AF při použití objektivu [HD PENTAX-DA 560mm F5.6 ED AW].
• zvýšená stabilita pro celkový výkon.
* Obsahuje také to co bylo ve verzi 1.01.
Změny verze V1.01 (17. 1. 2013)
• Umožnění nastavení kontrastu monitoru. (Do menu [LCD setting] přidána položka [Contrast]).
• Zvýšení celkové stability.
Pozor
Tento update firmware je určen pouze pro uživatele K-5 II/K-5IIs.
1.07_Mac.zip
(9.6 MiB) Staženo 133 x
1.07_Win.zip
(9.48 MiB) Staženo 170 x
1.06_Mac.zip
(9.49 MiB) Staženo 148 x
1.06_Win.zip
(9.6 MiB) Staženo 157 x
1.05_Mac.zip
(9.49 MiB) Staženo 137 x
1.05_Win.zip
(9.6 MiB) Staženo 153 x
1.04_Mac.zip
(9.49 MiB) Staženo 133 x
1.04_Win.zip
(9.6 MiB) Staženo 163 x
1.03_Mac.zip
(9.49 MiB) Staženo 156 x
1.03_Win.zip
(9.6 MiB) Staženo 148 x
1.02_Mac.zip
(9.49 MiB) Staženo 145 x
1.02_Win.zip
(9.6 MiB) Staženo 158 x
1.01_Mac.zip
(9.49 MiB) Staženo 164 x
1.01_Win.zip
(9.6 MiB) Staženo 139 x
Zpět na „Firmware“
