Firmware pro Pentax Q
Příspěvek od TomášFencl » 14 kvě 2012, 12:20
Firmware pro PENTAX Q
Changes to V1.13 (4.7.2013)
Correspond to [PENTAX-07 MOUNT SHIELD LENS].
Note: When update is executed, the camera setting will be returned to default setting. We recommend you to make a memorandum the setting of your camera before updating.
*Contents of [Version 1.12] and earlier version will be also updated.
Changes to V1.12 (18.4.2013)
Corrected --- Tone Expansion of Smart Effect is not effect correctly in firmware version 1.11.
*If you have already updated to Version1.11, we are very sorry for this inconvenience. Please update to Version 1.12.
*Contents of [Version 1.11] and earlier version will be also updated.
Changes to V1.11
Improved contrast AF performance.
Changes to V1.10 (25. 10. 2012)
Correspond to [Adapter Q for K-mount Lenses]. How to input focal length http://www.pentax.jp/english/support/di ... t_lens.pdf
Correspond to [PENTAX-06 TELEPHOTO ZOOM]
Note: When update is executed, the camera setting will be returned to default setting.We recommend you to make a memorandum the setting of your camera before updating.
Changes to V1.01 (2.11.2011)
•Improved the resolution when set ting Fine Sharpness.
•Improved stability for general performance.
01 STANDARD PRIME (Ver:1.01)
* Improved stability for general performance.
02 STANDARD ZOOM (Ver:1.01)
PENTAX Q Lenses : 01 STANDARD PRIME and 02 STANDARD ZOOM
fwlq101.bin (260Kbytes) for 01 STANDARD PRIME
fwlq102.bin(260Kbytes) for 02 STANDARD ZOOM
Změny v1.13 (4.7.2013)
Odpovídá [PENTAX-07 MOUNT SHIELD LENS].
Upozornění: Pokud se provádí aktualizace, nastavení fotoaparátu se vrátí do výchozího stavu. Doporučujeme provést záznam nastavení fotoaparátu před aktualizací.
* Obsah [verze 1.12] a dřívějších je v této verzi také obsažen.
Změny v1.12
Opraveno --- Smart Effect v Tone Expansion nebyl správně aplikován ve firmware verze 1.11.
* Pokud jste již aktualizován na verzi 1.11, velice se omlouváme se za tuto nepříjemnost. Prosím aktualizujte na verzi 1.12.
Poznámka: Pokud se provádí aktualizace, nastavení fotoaparátu se vrátí do výchozího stavu. Doporučujeme provést záznam nastavení fotoaparátu před aktualizací.
* Obsah [verze 1.11] a dřívější je také obsažen.
Změny v1.11
Vylepšený výkon kontrastního AF.
Změny ve verzi V1.10 (25. 10. 2012)
• Změny pro [Adaptér Q pro K-bajonetem]. Jak vložit ohniskovou vzdálenost http://www.pentax.jp/english/support/di ... t_lens.pdf
• Změny pro [PENTAX-06 ZOOM teleobjektiv]
• Vylepšená stabilita pro celkový výkon.
* Obsah [verze 1.01] je také obsažen.
Změny ve verzi V1.01 (2.11.2011)
• Vylepšené rozlišení při nastavení Fine Sharpness.
• Vylepšená stabilita pro všeobecný výkon.
fwlq101.bin (260Kbytes) pro 01 STANDARD PRIME
fwlq102.bin(260Kbytes) pro 02 STANDARD ZOOM
1.13_Mac.zip
(7.68 MiB) Staženo 126 x
1.13_Win.zip
(7.89 MiB) Staženo 122 x
1.12_MAC.zip
(7.72 MiB) Staženo 137 x
1.12_WIN.zip
(7.88 MiB) Staženo 128 x
1.11_MAC.zip
(7.72 MiB) Staženo 127 x
1.11_Win.zip
(7.88 MiB) Staženo 121 x
1.10_Mac.zip
(7.79 MiB) Staženo 117 x
1.10_Win.zip
(7.99 MiB) Staženo 116 x
fwlq101.zip
(38.41 KiB) Staženo 139 x
fwlq102.zip
(49.3 KiB) Staženo 136 x
1.01_Mac.zip
(7.64 MiB) Staženo 139 x
1.01_Win.zip
(7.81 MiB) Staženo 136 x
Zpět na „Firmware“
