Firmware pro Pentax 645D
Příspěvek od TomášFencl » 24 úno 2011, 18:21
Changes to V1.31 (12. 9. 2013)
Correspond to the AF assist light function by white LED light for auto flash unit [AF360FGZII] and [AF540FGZII].
*Contents of [Version 1.30] and earlier version will be also updated.
Changes to V1.30 (20. 12. 2012)
Correspond to SR function of [HD PENTAX-D FA645 MACRO 90mmF2.8ED AW SR]
Added [37. Shake Reduction] on Custom function
*If you update firmware, please update [PENTAX Digital Camera Utility 4]
*Contents of [Version 1.13] and earlier version will be also updated.
Changes to V1.13(1.3.2012)
•Improved reliability of recording operation when using SDXC memory card.
*If you have already updated to Version1.01or later, we are very sorry for this inconvenience. Please update to Version 1.13.
*Contents of [Version 1.11] and earlier version will be also updated.
Changes to V1.11(14.7.2011)
•Corrected method for obtain GPS data when developing RAW images that is contain GPS data on Version 1.10
*If you have already updated to Version1.10, we are very sorry for this inconvenience. Please update to Version 1.11.
Changes to V1.10(21.6.2011)
•Correspond to GPS unit [O-GPS1]
ASTROTRACER Function cannot be used.
*Contents of [Version 1.02] will be also updated.
Changes to V1.02 (10.3.2011)
•When processing Noise Reduction after long exposure, remaining time is displayed on LCD panel
•When mode dial is set to “X”, Flash X-Sync Speed can be set by custom function menu.
•When connecting to a computer via the USB cable, recognized Disk name is changed from [Removable Disk] to [645D].
If format SD memory card, volume label will be [645D].
•After mirror lock-up, extended standby time (until mirror automatically return to original position) from approximate 1 minute to 5 minutes
If Auto Power Off setting is shorter than 5 minutes, Auto Power Off setting has priority.
Changes to V1.01 (6.1.2011)
•Compatible with SDXC memory card.
* Transfer rate is not compatible with UHS speed class.
Změny ve verzi V1.31 (12. 9. 2013)
Upraveno pomocné AF světlo při práci s blesky [AF360FGZII] a [AF540FGZII].
* Obsah [verze 1.30] a starších verzí je také obsažen.
Změny ve verzi V1.30 (20. 12. 2012)
• Upravuje SR funkci pro [HD PENTAX-D FA645 MACRO 90mmF2.8ED AW SR]
• Přidává v Custom menu volbu [37. Shake Reduction]
* Jestliže aktualizujete firmware, prosím aktualizujte také [PENTAX Digital Camera Utility 4]
* Obsah verze 1.13 a starších verzí je také obsažen v tomto updatu.
Změny V1.13(1.3.2012)
Vyšší spolehlivost záznamu na paměťové karty SXDC.
Pokud jste již zaktualizovali na verzi 1.01 nebo vyšší, omlouváme se za tuto komplikaci. Prosím aktualizujte si na verzi 1.13.
Obsahuje také to co bylo ve verzi 1.11 a starších aktualizacích.
Změny v V1.11 (14.7.2011)
Opravena metoda pro získání GPS dat při tvorbě snímků RAW, která je obsažena v GPS datech na verzi 1.10.
* Pokud jste již aktualizovali na Version1.10, omlouváme se za tuto nepříjemnost. Prosím aktualizujte na verzi 1.11.
Změny v V1.10 (21.6.2011)
• změny týkající se jednotky GPS [O-GPS1]
Funkci ASTROTRACER nelze použít.
* Obsažena i aktualizace [Verze 1.02].
Změny v V1.02
• Při zpracování redukce šumu po dlouhé expozici, je potřebný čas zobrazen na LCD panelu
• Pokud volič režimů je nastaven na "X", můžete Flash X-Sync rychlost nastavit v menu funkce.
• Při připojení k počítači pomocí kabelu USB, jméno disku je změněno z [Vyměnitelný disk] na [645D]. Pokud naformátujete paměťovou kartu SD, bude jmenovka svazku [645D].
• Po zajištění skolpeného zrcátka se prodlužuje pohotovostní doba (do doby než se zrcátko automaticky vrátí do původní polohy) od přibližně 1 minuty až 5 minut. Pokud je Automatické vypnutí nastaveno na kratší dobu než 5 minut, má automatické vypnutí přednost.
* Obsažena i [Verze 1.01].
Změny v V1.01 (6.1.2011)
Kompatibilní s paměťovou kartu SDXC.
Přenosová rychlost není kompatibilní s třídou rychlostí UHS.
1.31_Mac.zip
(10.5 MiB) Staženo 118 x
1.31_Win.zip
(11.4 MiB) Staženo 115 x
1.30_Mac.zip
(10.5 MiB) Staženo 120 x
1.30_Win.zip
(11.4 MiB) Staženo 113 x
1.13_Mac.zip
(12.61 MiB) Staženo 126 x
1.13_Win.zip
(11.48 MiB) Staženo 120 x
1.11_Mac.zip
(12.61 MiB) Staženo 139 x
1.11_WIN.zip
(11.47 MiB) Staženo 126 x
1.10_Mac.zip
(12.61 MiB) Staženo 136 x
1.10_Win.zip
(11.48 MiB) Staženo 119 x
1.02_Mac.zip
(12.48 MiB) Staženo 112 x
1.02_Win.zip
(11.29 MiB) Staženo 128 x
1.01_Mac.zip
(12.47 MiB) Staženo 144 x
1.01_Win.zip
(11.28 MiB) Staženo 115 x
Zpět na „Firmware“
