Firmware pro Pentax K-5
Příspěvek od TomášFencl » 24 úno 2011, 18:18
Changes to V1.16 (6. 3. 2014)
Correspond to HD PENTAX-DA AF REAR CONVERTER 1.4X AW.
Improved stability for general performance
*Contents of [Version 1.15] and earlier version will be also updated.
Changes to V1.15 (12. 9. 2013)
Correspond to the AF assist light function by white LED light for auto flash unit [AF360FGZII] and [AF540FGZII].
Optimized contrast AF when using HD PENTAX-DA Limited series lenses.
*Contents of [Version 1.14] and earlier version will be also updated.
Changes to V1.14 (31.1.2013)
• Optimized contrast AF when using [HD PENTAX-DA 560mmF5.6ED AW] lens.
• Improved stability for general performance.
*Contents of [Version 1.13] and earlier version will be also updated.
Changes to V1.13(1.3.2012)
•Improved reliability of recording operation when using SDXC memory card.
*If you have already updated to Version1.02or later, we are very sorry for this inconvenience. Please update to Version 1.13.
*Contents of [Version 1.12] and earlier version will be also updated.
Changes to V1.12 (12.1.2012)
•Corrected --- When O-GPS1 is mounted on the K-5 and taking a picture of starry sky with long exposure tracing by ASTROTRACER function, a band of light green noise rarely occur on image depending on photographic condition.
*Contents of [Version 1.11] will be also updated.
Changes to V1.11 (14.7.2011)
•Corrected method for obtain GPS data when developing RAW images that is contain GPS data on Version 1.10.
*If you have already updated to Version1.10, we are very sorry for this inconvenience. Please update to Version 1.11.
Changes to V1.10 (21.6.2011)
•Correspond to GPS unit [O-GPS1]
Changes to V1.03 (10.3.2011)
•Improved the accuracy of auto focus in low-intensity light condition.
•Improved stability for general performance.
*Contents of [Version 1.02] will be also updated.
Changes to V1.02 (6.1.2011)
•Compatible with SDXC memory card.
* Transfer rate is not compatible with UHS speed class.
•All ISO sensitivity setting can be used on Bulb mode.
•Improved functional sequence for Contrast AF and improved total speed until in focus.
Changes to V1.01 (18.11.2010)
•Increases the number of continuous shot at RAW format and High sensitivity shooting.
* Ex. Setting condition: RAW/ISO100, Increases the number of continuous shot from maximum approx. 8 frames to approx. 20 frames.
•Improved stability for general performance such as exposure range on HyP mode
Zde byl trochu zmatek ve zveřejnění verzí update:
18.11.2010 zveřejněna verze 1.01
06.01.2011 zveřejněna verze 1.02 (v příloze označena 1.02.a)
18.01.2011 zveřejněna upravená verze 1.02 (v příloze označena 1.02.b)
09.02.2011 znovu zveřejněna původní verze 1.02 (1.02.a)
Změny V1.16 (6. 3. 2014)
* Obsah [verze 1.15] a starší verze jsou také obsaženy.
Změny V1.15 (12. 9. 2013)
Upraveno pomocné AF světlo při práci s blesky [AF360FGZII] a [AF540FGZII].
Optimalizováno AF pomocí detekce kontrastu při použití objektivů HD PENTAX-DA limited.
* Obsah [verze 1.14] a starších verzí je také obsažen.
Změny V1.14 (31. 1. 2013)
• Optimalizováno contrast AF při použití objektivu [HD PENTAX-DA 560mm F5.6 ED AW].
• zvýšená stabilita pro celkový výkon.
* Obsahuje také to co bylo ve verzi 1.13 a starších aktualizacích.
Změny V1.13(1.3.2012)
• Vyšší spolehlivost záznamu na paměťové karty SXDC.
Pokud jste již zaktualizovali na verzi 1.01 nebo vyšší, omlouváme se za tuto komplikaci. Prosím aktualizujte si na verzi 1.13.
* Obsahuje také to co bylo ve verzi 1.11 a starších aktualizacích.
Změny v V1.12 (12.1.2012)
• Opraveno --- Pokud je O-GPS1 namontovaný na K-5 a fotíte hvězdnou oblohu s dlouhou expozicí sledovací funkcí ASTROTRACER, občas se vyskytl světle zelený šum v obrazu v závislosti na fotografických podmínkách.
* Obsažena i aktualizace [verze 1.11].
Změny v V1.11 (14.7.2011)
• Opravena metoda pro získání GPS dat při tvorbě snímků RAW, která je obsažena v GPS datech na verzi 1.10.
* Pokud jste již aktualizovali na Version1.10, omlouváme se za tuto nepříjemnost. Prosím aktualizujte na verzi 1.11.
Změny v V1.10 (21.6.2011)
• změny týkající se jednotky GPS [O-GPS1]
* Obsažena i aktualizace [Verze 1.03].
Změny v V1.03 (10.3.2011)
• Vylepšená přesnost automatického zaostřování při zhoršených světelných podmínkách.
• Celkově vylepšená stabilita.
* Obsažena i aktualizace [Verze 1.02].
Změny v V1.02 (6.1.2011)
• Doplněna kompatibilita pro SDXC paměťové karty.
* Přenosová rychlost není kompatibilní s třídou rychlostí UHS.
• Všechny citlivosti ISO mohou být použity v režimu Bulb.
• Vylepšená funkční sekvence pro Contrast AF a zlepšení celkové rychlosti ostření.
* Obsah [Verze 1.01] je také zahrnut.
Změny v V1.01 (18.11.2010)
• Zvyšuje se počet kontinuálních záběrů ve formátu RAW a vysoká citlivost snímání.
* Např. Nastavení stavu: RAW/ISO100, zvyšuje se počet záběru z maximálních cca. 8 snímků na cca. 20 snímků.
• Vylepšená stabilita obecné výkonnosti, jako je expoziční rozsah v HyP režimu
1.16_Mac.zip
(9.31 MiB) Staženo 141 x
1.16_Win.zip
(9.44 MiB) Staženo 184 x
1.15_Mac.zip
(9.31 MiB) Staženo 132 x
1.15_Win.zip
(9.44 MiB) Staženo 162 x
1.14_Mac.zip
(9.32 MiB) Staženo 139 x
1.14_Win.zip
(9.44 MiB) Staženo 169 x
1.13_Mac.zip
(9.64 MiB) Staženo 160 x
1.13_Win.zip
(9.45 MiB) Staženo 189 x
1.12_MAC.zip
(9.65 MiB) Staženo 151 x
1.12_WIN.zip
(9.45 MiB) Staženo 155 x
1.11_MAC.zip
(9.64 MiB) Staženo 158 x
1.11_WIN.zip
(9.45 MiB) Staženo 173 x
1.10_Mac.zip
(9.64 MiB) Staženo 135 x
1.10_Win.zip
(9.45 MiB) Staženo 166 x
1.03_Mac.zip
(9.5 MiB) Staženo 164 x
1.03_Win.zip
(9.26 MiB) Staženo 181 x
1.02.b_Mac.zip
(9.5 MiB) Staženo 149 x
1.02.b_Win.zip
(9.26 MiB) Staženo 159 x
1.02.a_Mac.zip
(9.5 MiB) Staženo 150 x
1.02.a_Win.zip
(9.25 MiB) Staženo 166 x
1.01_Mac.zip
(9.45 MiB) Staženo 146 x
1.01_Win.zip
(9.2 MiB) Staženo 154 x
Zpět na „Firmware“
