Firmware pro Pentax K-r
Příspěvek od TomášFencl » 24 úno 2011, 18:11
Changes to V1.14 (12. 9. 2013)
Correspond to the AF assist light function by white LED light for auto flash unit [AF360FGZII] and [AF540FGZII].
Optimized contrast AF when using HD PENTAX-DA Limited series lenses.
*If the collaboration model is updated with this software, original start-up screen is deleted and it is changed to standard start-up screen.
*Contents of [Version 1.13] and earlier version will be also updated.
Changes to V1.13 (31. 1. 2013)
• Optimized contrast AF when using [HD PENTAX-DA 560mmF5.6ED AW] lens.
• Improved stability for general performance.
* If the collaboration model is updated with this software, original start-up screen is deleted and it is changed to standard start-up screen.
* Contents of [Version 1.12] and earlier version will be also updated.
Changes to V1.12(1.3.2012)
•Improved reliability of recording operation when using SDXC memory card.
*If you have already updated to Version1.01or later, we are very sorry for this inconvenience. Please update to Version 1.12.
*Contents of [Version 1.11] and earlier version will be also updated.
Changes to V1.11 (14.7.2011)
•Corrected method for obtain GPS data when developing RAW images that is contain GPS data on Version 1.10
*If you have already updated to Version1.10, we are very sorry for this inconvenience. Please update to Version 1.11.
Changes to V1.10 (21.6.2011)
•Correspond to GPS unit [O-GPS1]
Changes to V1.01 (6.1.2011)
•Compatible with SDXC memory card.
* Transfer rate is not compatible with UHS speed class.
•All ISO sensitivity setting can be used on Bulb mode.
•Improved functional sequence for Contrast AF and improved total speed until in focus.[/color]
Změny V1.14 (12. 9. 2013)
Upraveno pomocné AF světlo při práci s blesky [AF360FGZII] a [AF540FGZII].
Optimalizováno AF pomocí detekce kontrastu při použití objektivů HD PENTAX-DA limited.
* Pokud je model aktualizován s tímto programem, je původní úvodní obrazovka odstraněna a změní se na standardní úvodní obrazovku.
* Obsah [verze 1.13] a starších verzí jsou také obsaženy.
Změny V1.13 (31. 1. 2013)
• Optimalizováno contrast AF při použití objektivu [HD PENTAX-DA 560mm F5.6 ED AW].
• zvýšená stabilita pro celkový výkon.
* Jestliže spolupracující model je aktualizován s tímto programem, je původní úvodní obrazovka odstraněna a nahrazena standardní úvodní obrazovkou.
* Obsahuje také to co bylo ve verzi 1.12 a starších aktualizacích.
Změny v1.12 (1.3.2012)
• Vyšší spolehlivost záznamu na paměťové karty SXDC.
* Pokud jste již zaktualizovali na verzi 1.01 nebo vyšší, omlouváme se za tuto komplikaci. Prosím aktualizujte si na verzi 1.12.
* Obsahuje také to co bylo ve verzi 1.11 a starších aktualizacích.
Změny v V1.11 (14.7.2011)
• Opravena metoda pro získání GPS dat při tvorbě snímků RAW, která je obsažena v GPS datech na verzi 1.10.
* Pokud jste již aktualizovali na Version1.10, omlouváme se za tuto nepříjemnost. Prosím aktualizujte na verzi 1.11.
Změny v V1.10 (21.6.2011)
• změny týkající se jednotky GPS [O-GPS1]
* Obsažena i aktualizace [Verze 1.01].
Změny v V1.01 (6.1.2011)
• Doplněna kompatibilita pro SDXC paměťové karty.
* Přenosová rychlost není kompatibilní s třídou rychlostí UHS.
• Všechny citlivosti ISO mohou být použity v režimu Bulb.
• Vylepšená funkční sekvence pro Contrast AF a zlepšení celkové rychlosti ostření.
1.14_Mac.zip
(9.17 MiB) Staženo 122 x
1.14_Win.zip
(9.33 MiB) Staženo 162 x
1.13_Mac.zip
(9.17 MiB) Staženo 137 x
1.13_Win.zip
(9.33 MiB) Staženo 165 x
1.12_Mac.zip
(9.57 MiB) Staženo 129 x
1.12_Win.zip
(9.35 MiB) Staženo 168 x
1.11_MAC.zip
(9.57 MiB) Staženo 143 x
1.11_WIN.zip
(9.35 MiB) Staženo 169 x
1.10_Mac.zip
(9.57 MiB) Staženo 147 x
1.10_Win.zip
(9.35 MiB) Staženo 149 x
1.01_Mac.zip
(9.42 MiB) Staženo 140 x
1.01_Win.zip
(9.15 MiB) Staženo 172 x
Zpět na „Firmware“
