Firmware pro Pentax K-7
Příspěvek od TomášFencl » 24 úno 2011, 17:00
Changes to V1.12(1.3.2012)
•Improved reliability of recording operation when using SDXC memory card.
*If you have already updated to Version1.01or later, we are very sorry for this inconvenience. Please update to Version 1.13.
*Contents of [Version 1.11] and earlier version will be also updated.
Changes to V1.11 (13.1.2011)
•Compatible with SDXC memory card.
* Transfer rate is not compatible with UHS speed class.
* Contents of [Version 1.01 ~1.10] will be also updated.
Changes to V1.10 (28.7.2010)
•Added Movie editing function on playback mode palette. You can divide a movie into multiple segments and erase unwanted segments from the movie. How to operate the function, Click Here.
•Added Electronic Level indication on the Monitor
•When Mode dial is set M or X and Electronic Level is set to display, exposure meter is indicated both of them in the LCD panel and in the Viewfinder
•Added [Reversal Film] mode on Custom Image function [PENTAX Digital Camera Utility 4] have been updated. For update software, Click Here
•When using Live View, auto focus activate by pressing shutter release button halfway. Also improved focus speed
Changes to V1.03 (18.2.2010)
•Lens Correction (Distortion, Lateral chromatic aberration) is settable for below FA limited lenses.
smc PENTAX-FA 31mmF1.8AL Limited
smc PENTAX-FA 43mmF1.9 Limited
smc PENTAX-FA 77mmF1.8 Limited
•Improved usability by optimize the program of vertical position judgment.
•Improved stability of recording movie for some SDHC Memory card.
Changes to V1.02 (22.10.2009)
•Added [Fine Sharpness 2] which makes image outlines even sharper than [Fine Sharpness] to the Sharpness setting of Custom Image. How to select [Fine Sharpness 2].
•Improved total image processing performance at the particular shooting condition or setting such as preview image quality at the "Water Color & Pastel" of Digital Filter mode.
•Improved stability for general performance such as with Battery Grip D-BG4, the rear e-dial may rarely become unstable in particular shooting condition.
Changes to V1.01 (29.7.2009)
•Added [Operate at AF point “SEL”] on [Custom] menu and it can be selected either [1 Calling Function Preference] or [2 Select AF point Preference].
When selected [2 Select AF point Preference] and AF point switching dial is set at [SEL], selection of AF point can be operated priority by the four-way controller.
For example: when left- end focus point is selected, function of auto focus may rarely become unstable in particular shooting condition.
Změny V1.12(1.3.2012)
• Vyšší spolehlivost záznamu na paměťové karty SXDC.
* Pokud jste již zaktualizovali na verzi 1.01 nebo vyšší, omlouváme se za tuto komplikaci. Prosím aktualizujte si na verzi 1.12.
* Obsahuje také to co bylo ve verzi 1.11 a starších aktualizacích.
Změny na v1.11 (13.1.2011)
• Kompatibilita pro SDXC paměťové karty.
* Přenosová rychlost není kompatibilní s třídou rychlostí UHS.
* Obsah [Verze 1.01 ~ 1.10] je také obsažen.
Změny v 1.10 (28.7.2010)
• Přidána funkce na editaci filmu v režimu přehrávání. Můžete rozdělit film na více segmentů a vymazat nežádoucí segmenty z filmu. Podrobnosti http://www.pentax.jp/english/support/di ... _movie.pdf .
• Přidáno Elektronická indikace úrovně na monitoru
• Pokud volič expozičních režimů je nastaven na M nebo X a elektronická úroveň je nastavena na zobrazení, expoziční hodnoty jsou uvedeno jak je v LCD panelu tak i v hledáčku.
• Do Custom Image function [PENTAX Digital Camera Utility 4] byla přidána funkce [Reversal Film].
• Při použití živého náhledu Live View, je možné aktivovat automatické ostření stisknutím tlačítka spouště do poloviny. Také zlepšena rychlost ostření.
Změny na v1.03 (18.2.2010)
• Korekce objektivů (Distortion, boční chromatické aberace) je nastavitelná pro níže uvedené FA Limited objektivy.
smc PENTAX-FA Limited 31mm F1.8 AL
smc PENTAX-FA 43mm F1.9 Limited
smc PENTAX-FA 77mm F1.8 Limited
• Lepší využitelnost optimalizačního programu pro svislou polohu.
• Vylepšená stabilita záznamu filmu na některé SDHC paměťové karty.
Změny v V1.02 (22.10.2009)
• K nastavení vlastní ostrosti obrázků přidána funkce [Fine Sharpness 2], která vytváří ostřejší obraz než [Fine Sharpness]. Jak vybrat [Jemné Ostrost 2] http://www.pentax.jp/english/support/di ... ness_2.pdf .
• Lepší celkový výkon zpracování obrazu při fotografování ve zvláštním režimu jako je kvalita náhledu při použití digitálního filtru "Water Color & Pastel".
• Vylepšená stabilita pro battery grip D-BG4, vzácně se mohlo stát použití zadního e-kolečka nestabilní.
Změny v V1.01 (29.7.2009)
• Do [Custom] menu přidána volba [Operate at AF point “SEL”], kde může být zvoleno buď [1 Calling Function Preference] or [2 Select AF point Preference].
Když vyberete [2 Select AF point Preference] a přepínač je v poloze [SEL], výběr bodu AF lze ovládat pomocí čtyřicestného tlačítka. Jak nastavit tuto funkci http://www.pentax.jp/english/support/di ... te_k-7.pdf .
• Vylepšená stabilita pro všeobecný výkon
Například: pokud je vybrán pro ostření levý krajní bod, může být funkce automatického zaostřování občas nestabilní.
1.12_Mac.zip
(9.3 MiB) Staženo 127 x
1.12_Win.zip
(9 MiB) Staženo 157 x
1.11_Mac.zip
(9.31 MiB) Staženo 141 x
1.11_Win.zip
(9 MiB) Staženo 148 x
1.10_Mac.zip
(9.27 MiB) Staženo 133 x
1.10_Win.zip
(8.95 MiB) Staženo 129 x
1.03_Mac.zip
(9.2 MiB) Staženo 121 x
1.03_Win.zip
(8.86 MiB) Staženo 146 x
1.01_Mac.zip
(9.18 MiB) Staženo 132 x
1.01_Win.zip
(8.83 MiB) Staženo 127 x
Zpět na „Firmware“
