Pentax K-1 - novy firmware
Pentax K-1 Firmware v1.20 Released
Corresponded to [KAF4 lens mount] that is equipped with an electromagnetic diaphragm control system.
Enable new lens HD PENTAX-DA 55-300mmF4.5-6.3ED PLM WR RE to shoot stable by updating firmware.
http://www.ricoh-imaging.co.jp/english/ ... al/k1.html
Re: Pentax K-1 - novy firmware
...ono ten nový firmware je vydán pro těla K-1, K-S1, K-S2 a K-3II
Mrkněte na tyto stránky:
http://www.ricoh-imaging.co.jp/english/index.html
Díky za echo!
29.9. 2016 by mel vyjit novy firmware pro K-1 (asi ho chteli vydat drive, ale objevili nejakou chybku
http://news.ricoh-imaging.co.jp/rim_inf ... 12424.html
Release of the function expand Firmware version 1.30 for PENTAX K-1
RICOH IMAGING COMPANY, LTD. is pleased to announce the release of the function expanding Firmware version 1.30 for PENTAX K-1 digital SLR camera (launched on April, 2016) on September 29, 2016.
The function expand firmware is to add new function or increase number of setting for currently used PENTAX K-1 camera, so that improve the function, easy handling and update to the latest function.
You can download the free function expand firmware at the official website.
Enhanced functions (PENTAX K-1 V1.30)
Release date : September 29, 2016
New Enhanced Functions
*The Electronic Shutter at Live View mode
The Electronic Shutter can be selected at the Menu to reduce camera shake from the mechanical shutter when shooting with Live View mode.
*Add the [1:1] format at the Crop mode
Added and selectable [Square format (1:1)] size at the Crop mode.
*Add [2 frames bracketing] for the [AA Filter Simulator bracketing]
Addition to the current [3 frames bracketing (OFF, TYPE1, TYPE2)], the [2 frames bracketing (OFF, TYPE2)] is added and selectable for the [AA Filter Simulator bracketing]
*Smart Function
At the [BKT] setting, the bracketing range [±0 (=single frame)] can be selected.
[Others]
*Improved stability for general performance.
*Smart Function
[Others]
V návaznosti na jasanka informace z českého netu o novém fw pro šťastné majitele vlajkové lodi z dílny Pentax:
http://www.digimanie.cz/firmware-130-pr ... verku/6717
Dnes jsem měl po dlouhé době volný den.
Aktualizoval jsem firmware z verze 1.00 na verzi 1.30.
Za umělého světla jsem krátce zkoušel pouze Sigmu 34/1,4 Art.
Subjektivně zpomalila, ale vše na clonu 1,4 trefuje na 100%.
V týdnu vyzkouším další skla. Zajímá mne hlavně 100/2,8 macro na blízkou vzdálenost.
fakt: tak daj potom vediet ako sa ti pozdava DFA100 na fw1.30. mne sa nezda, ze by mi FA Limited (DFA mi islo aj pri skusani vonku tusim dobre aj pri f1.20) skla zpomalili, mozno aj hej, ak by som to vedel vôbec dako "zmerat", ale co som si vsimol, ze prestali huntovat.
DA*200 neviem ci som mal uz kupenu a zabehanu na fw1.20, asi skor nie, takze ju nemam s cim porovnat, celkovo SDM ostri o dost pomalsie ako skla cez srob... (a HSM je len o chlp rychlejsi, alebo o dva chlpy od SDM)
Jen nemůžu najít zmiňovanou elektronickou závěrku. Mám ji v menu, ale není povolena.
Nevíš co s tím?
Nevíš co s tím?
ako tu elektron.zavierku chces zapnut?
- cez tlacitko MENU, 2, LV Electronic Shutter, ES ON - ES OFF
- ZAPNES LiveView, tlacitko INFO, ES ON - ES OFF
ked mas zapnuty fotak a fotis cez hladacik a stlacis tlacitko INFO, je ES ON- ES OFF vyšedené, pretoze je to IBA pre LiveView fotenie
PS: Elektronicka zavierka sa neda aktivovat akurat v rezimoch Bulb a X.
Tak bohužel.
Po stisku INFO ES v tabulce vůbec nemám.
Vůbec nevím, co s tím dělat.
tak si tam ES pridaj, cely info panel sa da editovat
stlac INFO, postav sa kam ho chces dat, potom "+/-" vedla spuste, potom OK a vyber si ho tam z rolovacej tabulky a potvrd OK..
Ty jsi normálně chodící manuál.
Dopsal jsem to do tabulky.
Aktivní prvky v ní mám na šedém pozadí a neaktivní na černém. ES zůstalo černé OFF a já na tuto položku nemůžu vůbec najet, abych ji potvrdil.
neviem preco ti to nejde zapnut. ak nie si v rezime Bulb alebo X, tak to musi ist, ked si v LV mode a stlacis INFO tlacidlo.
este skusit urobit reset fotaku, ak si to doteraz po nahrati fw1.30 neurobil.
popis ES (ci nemas nieco zapnute, co to blokuje povolit):
http://www.ricoh-imaging.co.jp/english/ ... atures.pdf
Díky Lubor,
pomohl reset.
pomohl reset.
Včera jsem vzal K-1 na trénink do haly. Chtěl jsem prvně v životě vyzkoušet AF-C. Světla málo a na čas 1/500s a max ISO 6400 jsem na Sigmě 35/1,4 nastavil nejnižší clonu. Použil jsem středový bod. Při tom ohnisku je těžké udržet vzdálenou postavu na bodu, ale jak se přiblíží, problém mizí. Přesnost je vzhledem k cloně neuvěřitelná. Normálně váhám, zda nezačnu fotbal fotit na AF-C.
