navod K-x
http://www.ricoh-imaging.co.jp/english/ ... df/k-x.pdf
strana 221: You can connect the camera to a TV or other device with a video IN jack and play back images. Use the optional AV cable (I-AVC7)
podla tohoto mi to vychadza, ze K-x vie fotky a video iba prehrat (co je uz ulozene na karte), vo fotaku sa da nastavit pri Video vystupe uz len norma televizora (NTSC/PAL).
neviem, mozno ide aj vidiet obraz na TV pocas fotenia s K-x, nemam ho, ale skor tipujem ze nie.
EDIT: inde v navode som nasiel este toto:
The camera can also output composite video so that
you can view recorded images and movies on a monitor such as a TV screen.
...cize to co uz mam nafotene, nie pocas fotenia.
