K-7 / Digital Camera Utility 4
Ká sedmičkáři, jak moc používáte DCU 4 a jak se vám co osvědčilo? Pusťte nějaké zkušenosti do éteru.
O zlepšení redukce šumu není ve výčtu změn žádná zmínka:
* Support for the K-x camera
* Added [Picture: Blue Sky] and [Picture: Sunset] on Image data display of the custom.
* Added [Cross Processing] on Image Data display.
* Added lens data – [smc PENTAX-DA L55-300mmF4-5.8 ED]
* It is maintained the status of Image data display and Histogram display on main image display window.
* Corrected - When viewing rotated image such as rotated by Windows Photo gallery, it may shut down the software.
* Corrected - When cancel [Bold] of [Indicate changes in Image Data During Frame Advance], it is not canceled.
* Corrected - When display image that is captured with AF select, AF area mode on Image Data is displayed [- - - -].
* When [Save as….] is selected, image cannot overwrite to original file. It is changed to enable overwrite with permission of user.
* Corrected - The value of the white balance fine-tuning is not reflected to Fine tune of camera setting on White balance setting.
* Corrected - The coordinate value of Cropping is not reflected on the image.
* Improved stability of general performance.
...vďaka, ...no ešte tá prvá verzia často padala, zdá sa, že toto je vyriešené...
LR som chvíľku skúšal, ACR je niečo veľmi podobné...výstup sa mi ale farebne vôbec nepáčil/možno len bolo treba pohrať sa s profilmy či ako sa to volá...
Oproti nim mi u Pentax softu chýba doostrovanie cez nastavovanie 3 parametrov....inak veľmi nič...ale ešte raz - nevládnem posprocesu.
