Debug mode jentak??
Debug mode jentak??
Zdravim, je to na zavadu kdyz se mi po prvnim spusteni K20D objevi debug mode? Da se jim nak proklikat pryc nebo ho vypnout? Diky
Jednoduse ho vypnes:
http://pentax-hack.info/documents/debug.html
Je na to takovy maly programek v rustine, tenhleten. Puzivam ho na K10D, jak to bude na K20 nevim:
http://www.broadbandreports.com/r0/down ... ng.exe.zip
Zkus v tom "Debug menu" vybrat polozku "Debug mode" (sipkou doprava) a vybrat "Disable" a pak "OK". Po dalsim zapnuti uz by se nemelo objevit.
Pentax K10D + D-BG2 + O-ME53, Tamron 18-250mm F/3.5-6.3 AF Di-II LD IF Macro, Sigma 50mm f/2.8 EX DG AF Macro, Phoenix RL-59P Ringlight Flash, Nikon Coolpix S620, Giottos MTL 3361 B, ...
Ja mam K10D, postupoval jsem podle navodu zde: http://www.pentax-hack.info/documents/debug.htmlMarkusss píše:hele tak nejak nechapu kde mam cokoliv vybirat. Kdyz proste fotim tak sviti displej cerne a nahore v rohu sviti Debug Mode. jak se dostanu do toho menu ktere zminujes? Diky moc
Nahral jsem na kartu prislusny soubor s radkou: [OPEN_DEBUG_MENU]
a pak takovyhle postup:
To Enable the Debug mode:
1. Turn off your camera
2. Open the SD flash card door and leave it open
3. Turn on your camera. Now you should see the Debug Menu on your screen
4. Close the SD flash door
5. The menu stays on the screen. The first line of the Menu should read "Debug m
ode ". Use "->" button to toggle the Debug mode and to set it to Enable
6. Press "OK". Half pressing the shutter will have the "Debug mode" appear on th
e screen. Now you can have your fun with the AF corrections.
Please note, that if you switch the camera off and on, you will get back to the
"Debug menu" again. You will also get back to this menu when the camera wakes up
from the standby. Hitting "OK" will bring you back to the shooting mode with th
e "Debug mode" showing on your screen.
To Disable the "Debug mode" (all AF corrections are still stored in memory)
1. Switch off the camera
2. Turn the camera on
3. At the "Debug menu" use "->" button to disable the "Debug mode"
4. Press "OK" button. That's it. The "Debug mode" has gone. To Re-enable it, see
above .
Je to zbytecne podrobny navod - kdyz jsem si to procital, mel jsem strach abych tam neco nepokazil, ale v pohode jsem si debug pobvolil, v nem pak v custom menu vyzkousel korekci FF/BF a pak zase debug mode zrusil. Soubor mam stale na karte, takze kdykoliv mohu upravit korekci a zase se vratit.
Pro K20 by to melo byt podobne.
Tak sem dneska objevil novej problem, a to frontfocus... Jelikoz mi tam porad sviti ten dementi debug mode tak sem to chtel nak nastavit, ale nevim jak se dostat do nejakyho nastaveni... V uzivatelskym nastaveni sem zkousel Upravu AF , ale ostri to stejne pri -10 tak pri +10...
Pak se mi taky v "TEST MENU" pod setup menu ukazujou navic nejaky tri polozky kde je teda AF test kde je i Focus Corr, ale opet, at s tim hybu jak chci (-120mikrometru nebo +120mikrometru) tak je to opet stejny vysledek v ostreni.
Predtim nez me poslete do servisu kam budu muset zajit (ale nejdriv za 10dni) tak neexistuje jiny reseni?
mam ho stazenej , ale mam panickou hruzu z toho ho tam nahrat...Podelal se mi mobil kdyz sem tam daval FW a musel sem jit do servisu. No a od fotaku cekam neco podobnyhoRostislav.Linda píše:hoď to z okna...neee.. vtip zkoušel jsi nahrát jinej firmware?
O MODSET.xxx som cital uz davnejsie ale mne to akosi nefunguje. Mam K10D s fw 1.30, vytvorim na karte MODSET.TXT s obsahom [DEBUG_MODE EN], ale nikde mi nenaskoci ziadne menu, jedine co sa stane je ze 2x blikne podsvietenie velkeho LCD. Skusal som rozne prikazy, aj rozne velkosti kariet 16M az 8G, ale stale sa deje len to.
