Pentax K-m
nijel
Pentax K-m
Příspěvek od nijel » 19 zář 2008, 15:47
Tak už brzy bude nová low end DSLR od Pentaxu:
http://www.amazon.co.uk/Pentax-K-m-18-5 ... 99-7005411
Prý nejmenší zrcadlovka se stabilizací v těle...
nijel
Příspěvek od nijel » 19 zář 2008, 15:53
Pro případ, že by to smazali:
Product Features
* Built for the tough everyday photography
* 10.2 Megapixels resolution CCD
* ISO100-3200
* 3.5fps Continuous Shooting
* Reliable dust prevention, detection and removal system against dust on the sensor
* PENTAX "Shake Reduction" integrated into the camera body is usable with any Pentax lens
* Help function
* picture modes and automatic functions set the camera easily for each photograph situation
* 2.7" LCD
* Supplied with: DA L 18-55mm and 50-200mm zoom lens
Technical Details
CCD
10.75 Megapixels – total
10.2 Megapixels – effective
23.5x15.7mm Interline Interlace CCD with primary colour filter
Colour depth: 3 x 12 Bit in RAW, 3 x 8 Bit in JPEG (internal 3 x 22 bit)
Resolution:
- JPEG: (JPEG Baseline in quality steps of Optimal, Better, Good)
10 MP (3,872 x 2,592), 6 MP (3,008 x 2,000), 2 MP (1,824 x 1,216)
- RAW: 10 MP (3,872 x 2,592)
Sensitivity: Automatic, Manual selectable (ISO 100, 200, 400, 800, 1,600,3,200)
Lens
PENTAX KAF2 bayonet
Compatible with PENTAX KAF2-, KAF- and KA- lens mounts. Support for KAF2 Power Zoom functions
(K-mount lenses – with adapters – M42 and medium format lenses are mechanically compatible. Due to the high resolution of camera and lack of electronic contacts on the lenses no general statement can be made regarding full compatibility of functions.)
Viewfinder
Built-in, non-interchangeable Pentamirror finder
Viewing area 96% with finder magnification of 0.85x (with 50mm f/1.4 lens at infinity, -1m–1)
Bright non-interchangeable “Natural Bright II” focusing screen
Viewfinder indications below image area
Dioptre correction -2.5 dpt. – +1.5 dpt.
Monitor
2.7” low-temperature polysilicon TFT Monitor with 230,000 dots, brightness adjustment and wide viewing angle (approx. 160°)
Image previewing with image preview switch (stop down button)
Image view after recording: Single image, double image, Histogram, recording data and Hot Spot Warning, 16x enlargement, Thumbnail index (4, 9 or 16), slide show, image rotation
Preview
Depth-of-field preview button for focus depth preview, digital preview
Image Formats
RAW (PEF, DNG), RAW + JPEG
JPEG (Exif 2.21), DCF
JPEG compression: JPEG Baseline in quality steps of Optimal, Better, Good
Memory
SD Card, SDHC Card
Focus
Autofocus system: TTL Phase Matching with 5 focussing points (SAFOX) with indication in finder
Operational range: (EV 1 – EV 19)
AF Single with focus lock or continuous AF (as a function of the exposure program)
Focussing point selectable between automatic or manual choice, spot focussing
AF-Assist with built-in flash
Metering
16 segment TTL open aperture metering coupled with AF and lens information, switchable between Multi segment, Centre weighted and Spot metering.
Operational range: EV 1 – EV 21
Electronically controlled vertical-run focal plane shutter
Shutter speeds: Automatic: 1/4,000 – 30sec. (stepless), Manual: 1/4,000 – 30sec. (in 0.5 EV steps) and Bulb
Flash sync: 1/180sec.
Green Mode, Programmed automatic (Hyperprogram), Sensitivity Priority, Aperture Priority, Shutter Priority, ISO Automatic, Manual, long exposure
Picture Modes (automatic or manual): Portrait, Landscape, Macro, Sport, Night portrait, Flash Off
Scene Modes: Night scene, Surf & Snow, Food, Sunset, Kids, Pets, Candle light, Museum
Exposure compensation: +/- 2EV (1/3 or 1/2 steps)
Auto bracketing: +/-0.5 EV, +/-1.0 EV, +/-1.5 EV in 0.5 EV steps, or +/-0.3 EV, +/-0.7 EV, +/-1.0 EV, in 0.3 EV steps
Exposure memory button
Flash
Built-in P-TTL automatic flash with automatic operation in poor lighting conditions
Manual on / manual off
Preflash for reduction of the “Red Eye” effect
Flash compensation (±2 EV)
GN 13 at ISO 100
Hotshoe on camera top for use of system flashes
High-Speed Wireless Synchronisation with appropriate PENTAX flashes
Coverage 28mm (equivalent in 35mm film format)
Power requirements
4x AA batteries (Lithium, Alkaline, Ni-MH)
Battery capacity: approx. 1,650 images or approx. 1000 images (50% with flash) or approx. 750 min. playback
AC adapter (optionally available)
Connections
USB 2.0 (High Speed)
AV (compatible with NTSC and PAL)
AC adapter (optionally available adapter)
Recording parameters
White Balance: Automatic or manual. Daylight, Shade, Cloudy, Tungsten, Neon (W, N, D), Flash, manual balance, 3 selectable settings for Kelvin and Mired Value with fine adjust
Digital filters: BW, Sepia, Colour (18 options), Soft filter and Slim Filter, HDR (3 options)
Drive Modes: Single, Series (Hi/Low): 2.8fps. to 4 images in JPEG (Hi), 1.1fps to capacity of memory card (Low). 4 images in RAW (DNG). Auto Bracketing, Self-timer with 2sec. delay (mirror up lock) and 12sec. delay, IR Remote Control, series.
Special features
PENTAX developed opto/mechanical “Shake Reduction” (integrated in camera body). Adds approx. 4 stops to hand-held shots (for long exposures a tripod should be used).
3 step “Dust Removal” system:
1. Special coating of Low Pass Filter,
2. Vibration system to remove dust,
3. Adhesive strip to capture dust
“Dust Alert”: remaining persistent dust on the sensor is clearly located and the position is indicated on the monitor
Compatible with ultrasonic lenses
Camera internal file designation switchable between standard files or date
Extended exposure functions via eight Scenes Mode programs
Switchable between digital preview on the monitor or optical depth-of-field preview in viewfinder
23 individually adaptable camera functions
Metal chassis with fibre-reinforced plastic housing
Weather-proofed body construction with 60 seals protecting against dust and spray
World time for 72 cities in 28 time zones
Menu languages: English, French, German, Danish, Swedish, Finnish, Dutch, Spanish, Portuguese, Italian, Polish, Czech, Hungarian, Turkish, Russian, Korean, Chinese, Thai, Japanese
Print Functions
PictBridge, DPOF (Digital Print Order Form), PRINT Image Matching III
System requirements
Integrated USB connector
PC: Windows XP, Windows Vista
- CPU: Pentium IV or newer
- Memory: minimum 512MB
- Free hard drive space: 1GB or more
- Monitor resolution: 1,280 x 1,024 or more
Mac OS X 10.2 or higher
- CPU: POWER PC G5 or newer
Software
PENTAX PHOTO Browser 3/PENTAX PHOTO Laboratory 3 with integrated RAW converter
LENS 1 - 18-55mm DAL zoom Lens
Lens mount - PENTAX KAF-Bayonet
Angle of view - 76 – 29°
Construction - 11 elements / 8 groups
Aperture control - Automatic
Smallest aperture - 22 – 38
Metering - TTL open aperture Metering
Minimum focusing distance - 0.25m – ∞
Magnification - approx. 1:2.9 (0.34x)
Filter size - 52mm
LENS 2 - 50-200mm DAL zoom lens
Angle of view – 31.5° to 8.1°
Construction - 11 elements / 10 groups
Aperture control – Automatic
Smallest aperture – 22-32
Minimum focusing distance – 1.1m – ∞
Magnification - approx. 1:4.2 (0.24x)
Filter size - 52mm
Příspěvek od elho_cid » 19 zář 2008, 16:38
Kromě pár čudlíků a stavového displeje, které chybí, je to vlastně vylepšená K200D. Je nesmysl, aby K200D po půl roce prodeje prostě nehradili. Něco mi tady nehraje - leda že by ohlásili i K200D super s LV a snímačem z K20D. To by pak měli 3 foťáky pěkně odstupňované.
100r
Příspěvek od 100r » 20 zář 2008, 10:14
toto sa mi trocha nezda na 4 tuzkace... nuz, marketing je marketing.
elho_cid píše:Kromě pár čudlíků a stavového displeje, které chybí, je to vlastně vylepšená K200D. Je nesmysl, aby K200D po půl roce prodeje prostě nehradili. Něco mi tady nehraje - leda že by ohlásili i K200D super s LV a snímačem z K20D. To by pak měli 3 foťáky pěkně odstupňované.
tymto by ale mala problemy s predajom K200D
SvadobnyPribeh.com
cocik
Příspěvek od cocik » 22 zář 2008, 19:28
http://www.fotoradce.cz/novy-pentax-k-m.php
podrobny clanek i s fotkama z fotaku
Sony A7R III
Dmb
Příspěvek od Dmb » 22 zář 2008, 20:30
No nevím, lepší je podle mně K200D, i vzhledově i čudlíky jsou na k200D lépe umístěně. Nějak mi nepadl do oka. Ale některé věci na novém Pentnaxu jsou super, jako například docela vysoké ISO ale asi pak bude hodně vysoký šum. No uvidíme...
http://lukaskabon.cz
Příspěvek od elho_cid » 22 zář 2008, 20:49
Me na nem zaujalo, ze je navrzeny tak, aby se dal pouzivat jednou rukou. Kdybych k nemu pridelal hand strap, mam v ruce vec ktara foti stejne kvalitne jako moje K10D, ale v druhe ruce muzu pri foceni klidne drzet párek v rohlíku, nebo pivo.
Ta myslenka se mi libi.
Příspěvek od Alf » 22 zář 2008, 20:53
Popravdě vypadá dost dobře, tedy myslím opticky. Fakt krásnej design.
Příspěvek od elho_cid » 22 zář 2008, 21:20
Je k neuvěření, jak je malinkatej.
Dmb
Příspěvek od Dmb » 22 zář 2008, 21:50
Připadá mi že je poměrně malý. Nezdá se vám?
Instruktor
Příspěvek od Instruktor » 22 zář 2008, 22:17
Ne proto ze jsem zarytej Pentaxak, ale proto, ze je to zkratka fakt:
PENTAX MA proste opravdu NEJKRASNEJSI DESIGN!
No ne?!
http://commons.wikimedia.org/wiki/Category:Pentax_K10D
http://www.digitalreview.ca/cams/Pentax_K10D.shtml
I N S T R U K T O R
Motto:
,,Mám jednoduchý vkus. Spokojím se vždy s tím nejlepším." Mark Twain
http://petr.ipernity.com
cocik
Příspěvek od cocik » 22 zář 2008, 22:52
predtim jsem mel panasonica ultrazoom, rozdil v kvalite fotek je propastny 8O ... ale dalsi dve zmeny, ktere nejvic pocituji je velikost fotaku a vaha
kdyz vidim toho prcka K-m [v rukou toho chlapa], co umi hodne toho, co moje K20D, tak si rikam za PENTAX jde spravnym smerem
kdyz bych volil mezi hypersuper obrovskym a tezkym FF [znacka] a timto prckem, tak by vyhral pentaxi prcek
Sony A7R III
Bukic
Příspěvek od Bukic » 23 zář 2008, 06:20
K10d; Pentax A 50/1.7; Sigma 30/1.4DC EX; Pentax SMC A 135/2.8; Cosina 70-210/4; Sigma EF-53 DG SUPER :-)
lhendrych
Příspěvek od lhendrych » 23 zář 2008, 06:47
Na tom je krásně vidět jak jsme každej jinej. Já si nechal na svojí K100D udělat battery pack, aby mi líp seděl v ruce, taky díky tomu udržím o dost delší čas. Takže já hlasuju pro pořádný FF s integrovaným battery packem.
Pentax K7
Dr.Chocholousek
Příspěvek od Dr.Chocholousek » 23 zář 2008, 07:00
Bukic píše:A tu je tusim dalsia novinka
http://www.popphoto.com/cameras/5544/pe ... -look.html
no jak tak na to koukam tak K 2000 je to same jako K-m teda aspon na prvni pohled.
Tak pravil Dr.Chocholousek
Zpět na „Pentax K100/110D a K200D“
